Saltar al contenido principal
Lenovo Legion 5-15ACH6 SSD Replacement
Qué necesitas
  1. Lenovo Legion 5-15ACH6 SSD Replacement, SSD: paso 1, imagen 1 de 1
    • Prepare your work area on a flat surface.
    • Lay your laptop down with the back case facing up.
  2. Lenovo Legion 5-15ACH6 SSD Replacement: paso 2, imagen 1 de 1
    • Use a Philips #1 screwdriver to remove the six 11.1 mm on the back of the device.
    • Use a Philips #00 screwdriver to remove the four 4.1 mm screws on the back case.
  3. Lenovo Legion 5-15ACH6 SSD Replacement: paso 3, imagen 1 de 3 Lenovo Legion 5-15ACH6 SSD Replacement: paso 3, imagen 2 de 3 Lenovo Legion 5-15ACH6 SSD Replacement: paso 3, imagen 3 de 3
    • Starting from the back of the laptop slide your opening tool between the bottom cover and laptop chassis.
    • Run the opening tool along the seam to separate the bottom cover from the chassis.
    • Remove the bottom cover and place to the side.
  4. Lenovo Legion 5-15ACH6 SSD Replacement: paso 4, imagen 1 de 3 Lenovo Legion 5-15ACH6 SSD Replacement: paso 4, imagen 2 de 3 Lenovo Legion 5-15ACH6 SSD Replacement: paso 4, imagen 3 de 3
    • To disconnect the battery cable safely, use the pointed tip of a spudger to carefully push on each side of the connector.
    • Alternating from one side to the other, gently “walk” the connector out of its socket.
    • Always pull cables by their connectors and not the wires themselves.
    • Touching any electrical component with the battery plugged in can result in damage to the motherboard.
  5. Lenovo Legion 5-15ACH6 SSD Replacement: paso 5, imagen 1 de 2 Lenovo Legion 5-15ACH6 SSD Replacement: paso 5, imagen 2 de 2
    • Remove the three 4.1mm Phillips #00 screws holding the metal shield in place.
    • Remove the metal shield and place it to the side.
  6. Lenovo Legion 5-15ACH6 SSD Replacement: paso 6, imagen 1 de 1
    • Remove the single 4.1 mm Philips #00 screw holding the SSD in place.
    • Pull the SSD out and away from the socket.
Conclusión
4 personas más completaron esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 112
Todo El Tiempo: 633
