Saltar al contenido principal
Lenovo Ideapad S415 Touch RAM Replacement
Qué necesitas
  1. Lenovo Ideapad S415 Touch RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch RAM Replacement: paso 2, imagen 1 de 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch RAM Replacement: paso 3, imagen 1 de 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch RAM Replacement: paso 4, imagen 1 de 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch RAM Replacement: paso 5, imagen 1 de 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch RAM Replacement, RAM: paso 6, imagen 1 de 2 Lenovo Ideapad S415 Touch RAM Replacement, RAM: paso 6, imagen 2 de 2
    • Locate the five 6mm black screws on the bottom.
    • Using a Phillips #0 screwdriver, remove all five screws.
  7. Lenovo Ideapad S415 Touch RAM Replacement: paso 7, imagen 1 de 2 Lenovo Ideapad S415 Touch RAM Replacement: paso 7, imagen 2 de 2
    • Locate the three 4mm silver screws on the bottom area where the battery was removed.
    • Use the Phillips #0 screwdriver to remove all three screws.
  8. Lenovo Ideapad S415 Touch RAM Replacement: paso 8, imagen 1 de 3 Lenovo Ideapad S415 Touch RAM Replacement: paso 8, imagen 2 de 3 Lenovo Ideapad S415 Touch RAM Replacement: paso 8, imagen 3 de 3
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stoppers by lifting each with your hands.
  9. Lenovo Ideapad S415 Touch RAM Replacement: paso 9, imagen 1 de 3 Lenovo Ideapad S415 Touch RAM Replacement: paso 9, imagen 2 de 3 Lenovo Ideapad S415 Touch RAM Replacement: paso 9, imagen 3 de 3
    • Under each of the four stoppers, there will be a 6mm screw.
    • Use the Phillips #0 screwdriver to remove all four screws.
  10. Lenovo Ideapad S415 Touch RAM Replacement: paso 10, imagen 1 de 2 Lenovo Ideapad S415 Touch RAM Replacement: paso 10, imagen 2 de 2
    • Carefully open up the laptop to reveal the internal components.
  11. Lenovo Ideapad S415 Touch RAM Replacement: paso 11, imagen 1 de 3 Lenovo Ideapad S415 Touch RAM Replacement: paso 11, imagen 2 de 3 Lenovo Ideapad S415 Touch RAM Replacement: paso 11, imagen 3 de 3
    • Locate the RAM.
    • Using your hands gently push up on the two silver clips located on both ends of the RAM.
    • The RAM will spring out. Gently pull it out of the slot.
    • Do not touch the top yellow part of the RAM as this will cause damage.
Conclusión
Una persona más ha completado esta guía.
Alexandria
Miembro Desde 02/05/19
363 Reputación
2 Guías creadas
Equipo
UC Davis, Team S20-G5, Lore Winter 2019 Miembro de UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 771
