Saltar al contenido principal
Lenovo Ideapad S415 Touch Hard Drive Replacement
Qué necesitas
  1. Lenovo Ideapad S415 Touch Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 2, imagen 1 de 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 3, imagen 1 de 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 4, imagen 1 de 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 5, imagen 1 de 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch Hard Drive Replacement, Hard Drive: paso 6, imagen 1 de 2 Lenovo Ideapad S415 Touch Hard Drive Replacement, Hard Drive: paso 6, imagen 2 de 2
    • Locate the five black screws on the back.
    • Use a Phillips #0 screwdriver to remove all five black 6 mm screws.
  7. Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 7, imagen 1 de 2 Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 7, imagen 2 de 2
    • Locate the three silver screws underneath the battery.
    • Use the Phillips #0 screwdriver to remove all three 4 mm screws.
  8. Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 8, imagen 1 de 3 Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 8, imagen 2 de 3 Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 8, imagen 3 de 3
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stopper with your hands.
    • Use the Phillips #0 screwdriver to remove the 6 mm screws underneath all four stoppers.
  9. Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 9, imagen 1 de 1
    • Open the laptop carefully.
  10. Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 10, imagen 1 de 2 Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 10, imagen 2 de 2
    • Locate the hard drive.
    • Use the Phillips #0 screwdriver to remove the two 4 mm screws that are holding the hard drive in place.
  11. Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 11, imagen 1 de 1
    • The hard drive is now removed from the laptop.
  12. Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 12, imagen 1 de 2 Lenovo Ideapad S415 Touch Hard Drive Replacement: paso 12, imagen 2 de 2
    • Once the hard drive is removed, locate the four screws that hold the metal frame to the hard drive.
    • Use the Phillips #0 screwdriver to remove the 4 mm silver screws on all sides.
Conclusión
Casey Zhang
Miembro Desde 02/06/19
315 Reputación
2 Guías creadas
Equipo
UC Davis, Team S20-G5, Lore Winter 2019 Miembro de UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 500
