Saltar al contenido principal
Lenovo Ideapad S415 Touch Fan Replacement
Qué necesitas
  1. Lenovo Ideapad S415 Touch Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Fan Replacement: paso 2, imagen 1 de 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Fan Replacement: paso 3, imagen 1 de 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Fan Replacement: paso 4, imagen 1 de 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Fan Replacement: paso 5, imagen 1 de 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch Fan Replacement, Fan: paso 6, imagen 1 de 2 Lenovo Ideapad S415 Touch Fan Replacement, Fan: paso 6, imagen 2 de 2
    • Locate the five 6mm black screws on the bottom.
    • Using a Phillips #0 screwdriver, remove all five black screws.
  7. Lenovo Ideapad S415 Touch Fan Replacement: paso 7, imagen 1 de 2 Lenovo Ideapad S415 Touch Fan Replacement: paso 7, imagen 2 de 2
    • Locate the three 4mm silver screws on the bottom area where the battery was removed.
    • Using the Phillips #0 screwdriver, remove all three silver screws.
  8. Lenovo Ideapad S415 Touch Fan Replacement: paso 8, imagen 1 de 3 Lenovo Ideapad S415 Touch Fan Replacement: paso 8, imagen 2 de 3 Lenovo Ideapad S415 Touch Fan Replacement: paso 8, imagen 3 de 3
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stoppers by lifting each with your fingers.
  9. Lenovo Ideapad S415 Touch Fan Replacement: paso 9, imagen 1 de 3 Lenovo Ideapad S415 Touch Fan Replacement: paso 9, imagen 2 de 3 Lenovo Ideapad S415 Touch Fan Replacement: paso 9, imagen 3 de 3
    • Under each of the four stoppers, there will be a 6mm screw.
    • Use the Phillips #0 screwdriver to remove all four screws.
  10. Lenovo Ideapad S415 Touch Fan Replacement: paso 10, imagen 1 de 2 Lenovo Ideapad S415 Touch Fan Replacement: paso 10, imagen 2 de 2
    • Carefully open up the laptop to reveal the internal components.
  11. Lenovo Ideapad S415 Touch Fan Replacement: paso 11, imagen 1 de 2 Lenovo Ideapad S415 Touch Fan Replacement: paso 11, imagen 2 de 2
    • Locate the silver 6mm screw on the top of the fan
    • Locate the silver 4mm screw on the bottom of the fan
    • Use a Phillips #0 screwdriver to remove both screws.
  12. Lenovo Ideapad S415 Touch Fan Replacement: paso 12, imagen 1 de 2 Lenovo Ideapad S415 Touch Fan Replacement: paso 12, imagen 2 de 2
    • Locate the fan power connector.
    • Use a spudger or your hands to disconnect the fan power connector from its port.
  13. Lenovo Ideapad S415 Touch Fan Replacement: paso 13, imagen 1 de 2 Lenovo Ideapad S415 Touch Fan Replacement: paso 13, imagen 2 de 2
    • Once the fan power connector is disconnected, lift up the bronze heatsink and pull the wires out from underneath it.
    • Lift up the fan and pull free.
Conclusión
Alexandria
Miembro Desde 02/05/19
363 Reputación
2 Guías creadas
Equipo
UC Davis, Team S20-G5, Lore Winter 2019 Miembro de UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 208
