Saltar al contenido principal
Lenovo Ideapad S415 Touch Battery Replacement
  1. Lenovo Ideapad S415 Touch Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Battery Replacement: paso 2, imagen 1 de 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Battery Replacement: paso 3, imagen 1 de 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Battery Replacement: paso 4, imagen 1 de 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Battery Replacement: paso 5, imagen 1 de 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
Conclusión
Casey Zhang
Miembro Desde 02/06/19
315 Reputación
2 Guías creadas
Equipo
UC Davis, Team S20-G5, Lore Winter 2019 Miembro de UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 286
