Introducción
If you are unable to move the mouse and it is overly sensitive, use this guide to replace your touchpad.
Herramientas
Partes
No se especificaron partes.
Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery.
Locate the touch pad and remove the two 3 mm screws using a T5 Torx Screwdriver.
Casi Terminas!
Conclusión
