Saltar al contenido principal
Lenovo Ideapad Flex 4-1570 Touchpad Replacement
Qué necesitas
  1. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Back Panel: paso 1, imagen 1 de 1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: paso 2, imagen 1 de 1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: paso 3, imagen 1 de 1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Battery: paso 4, imagen 1 de 2 Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Battery: paso 4, imagen 2 de 2
    • Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery.
    • Do not pry or pull on the socket itself or you risk damaging the motherboard.
  5. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: paso 5, imagen 1 de 1
    • Remove the three 4 mm screws using a T5 Torx Screwdriver.
  6. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: paso 6, imagen 1 de 1
    • Remove the battery.
  7. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Touchpad: paso 7, imagen 1 de 1
    • Locate the touch pad and remove the two 3 mm screws using a T5 Torx Screwdriver.
  8. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: paso 8, imagen 1 de 1
    • Disconnect the touch pad chip from the motherboard.
  9. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: paso 9, imagen 1 de 1
    • Disconnect the bronze piece of tape from touch pad and set it off to the side.
  10. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: paso 10, imagen 1 de 2 Lenovo Ideapad Flex 4-1570 Touchpad Replacement: paso 10, imagen 2 de 2
    • Open the laptop and, with the assistance of the iFixit blue plastic tool, guide the touch pad through, it should come out on its own.
Conclusión
Isaiah Vang
Miembro Desde 10/04/18
669 Reputación
6 Guías creadas
Equipo
UW Stout, Team S6-G6, Ogden Fall 2018 Miembro de UW Stout, Team S6-G6, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G6
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 582
