Saltar al contenido principal
Lenovo Ideapad Flex 4-1570 Speakers Replacement
Qué necesitas
  1. Lenovo Ideapad Flex 4-1570 Speakers Replacement, Back Panel: paso 1, imagen 1 de 1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Speakers Replacement: paso 2, imagen 1 de 1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Speakers Replacement: paso 3, imagen 1 de 1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Speakers Replacement, Speakers: paso 4, imagen 1 de 2 Lenovo Ideapad Flex 4-1570 Speakers Replacement, Speakers: paso 4, imagen 2 de 2
    • Lift up on each speaker, one by one. The speaker should lift up with ease.
  5. Lenovo Ideapad Flex 4-1570 Speakers Replacement: paso 5, imagen 1 de 2 Lenovo Ideapad Flex 4-1570 Speakers Replacement: paso 5, imagen 2 de 2
    • Unwind the speaker wire from the plastic brackets. Once you have the wire completely unwinded, use two blue iFixit tools to disconnect the speaker chip from the motherboard.
Conclusión
Isaiah Vang
Miembro Desde 10/04/18
669 Reputación
6 Guías creadas
Equipo
UW Stout, Team S6-G6, Ogden Fall 2018 Miembro de UW Stout, Team S6-G6, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G6
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 228
