Saltar al contenido principal
Lenovo Ideapad Flex 15 Wireless Networking Card Replacement
Qué necesitas
  1. Lenovo Ideapad Flex 15 Wireless Networking Card Replacement, Bottom Panel: paso 1, imagen 1 de 2 Lenovo Ideapad Flex 15 Wireless Networking Card Replacement, Bottom Panel: paso 1, imagen 2 de 2
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 2, imagen 1 de 2 Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 2, imagen 2 de 2
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 3, imagen 1 de 3 Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 3, imagen 2 de 3 Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 3, imagen 3 de 3
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 4, imagen 1 de 1
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 5, imagen 1 de 3 Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 5, imagen 2 de 3 Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 5, imagen 3 de 3
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 6, imagen 1 de 2 Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 6, imagen 2 de 2
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
  7. Lenovo Ideapad Flex 15 Wireless Networking Card Replacement, Wireless Networking Card: paso 7, imagen 1 de 2 Lenovo Ideapad Flex 15 Wireless Networking Card Replacement, Wireless Networking Card: paso 7, imagen 2 de 2
    • Locate the wireless card. It is located above the black ribbon cable, underneath the battery terminals.
    • The wireless card has two antennas (black and white cables) that are attached to other parts of the laptop.
  8. Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 8, imagen 1 de 2 Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 8, imagen 2 de 2
    • To remove these cables, take your plastic opening tool and gently pry around the metal base above the PCB until the connectors are freed.
    • Repeat this step with both the black and the white antennas
  9. Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 9, imagen 1 de 3 Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 9, imagen 2 de 3 Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 9, imagen 3 de 3
    • There are two (30 mm) screws attached to the wireless card underneath the antenna. Remove both of these with your screwdriver (bit PH1).
    • Once the screws are removed, the wireless card will tilt upwards. Firmly grab the card with one hand and pull it slowly, diagonally, out of the socket.
    • To replace this card with a new wireless card, put the contacts back into the socket. The wireless card should be sitting at a 45 degree angle.
  10. Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 10, imagen 1 de 3 Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 10, imagen 2 de 3 Lenovo Ideapad Flex 15 Wireless Networking Card Replacement: paso 10, imagen 3 de 3
    • To seat the wireless card, put the two screws back into the card. It should be flush against the base of the laptop.
    • Line up the white antenna back in the original (left) terminal. Push the antenna gently onto the wireless adapter with one finger. Give it a small tug to ensure it is connected firmly.
    • Do the same with the black antenna, snapping it onto the right antenna port.
Conclusión
3 personas más completaron esta guía.
Brent
Miembro Desde 03/04/16
804 Reputación
6 Guías creadas
Equipo
Un comentario
I would like to upgrade my Lenovo Flex 15, model 20309, wifi card. It says I have wireless-N 7260 and I would like it upgraded to a fast dual band card. I am having trouble finding a wifi card that I am confident will be compatible with my laptop. Most of the 7260’s say they do not work with Lenovo. Any help is very much appreciated!
Brad Goldfinger - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 2,792
