Saltar al contenido principal
Lenovo Ideapad Flex 15 Bottom Panel Replacement
Qué necesitas
  1. Lenovo Ideapad Flex 15 Bottom Panel Replacement, Bottom Panel: paso 1, imagen 1 de 2 Lenovo Ideapad Flex 15 Bottom Panel Replacement, Bottom Panel: paso 1, imagen 2 de 2
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 Bottom Panel Replacement: paso 2, imagen 1 de 2 Lenovo Ideapad Flex 15 Bottom Panel Replacement: paso 2, imagen 2 de 2
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 Bottom Panel Replacement: paso 3, imagen 1 de 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: paso 3, imagen 2 de 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: paso 3, imagen 3 de 3
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 Bottom Panel Replacement: paso 4, imagen 1 de 1
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 Bottom Panel Replacement: paso 5, imagen 1 de 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: paso 5, imagen 2 de 3 Lenovo Ideapad Flex 15 Bottom Panel Replacement: paso 5, imagen 3 de 3
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 Bottom Panel Replacement: paso 6, imagen 1 de 2 Lenovo Ideapad Flex 15 Bottom Panel Replacement: paso 6, imagen 2 de 2
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
Conclusión
3 personas más completaron esta guía.
Brent
Miembro Desde 03/04/16
804 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 2,878
