Saltar al contenido principal
Lenovo Ideapad 330-15ARR Speaker Replacement
Qué necesitas
  1. Lenovo Ideapad 330-15ARR Speaker Replacement, Lower Case: paso 1, imagen 1 de 1
    • Remove all Phillips #0 screws securing the case to the laptop.
  2. Lenovo Ideapad 330-15ARR Speaker Replacement: paso 2, imagen 1 de 2 Lenovo Ideapad 330-15ARR Speaker Replacement: paso 2, imagen 2 de 2
    • Pry all edges off of the laptop with the opening tool until the lower case releases.
    • Remove the lower case.
  3. Lenovo Ideapad 330-15ARR Speaker Replacement, Speaker: paso 3, imagen 1 de 2 Lenovo Ideapad 330-15ARR Speaker Replacement, Speaker: paso 3, imagen 2 de 2
    • Remove the speaker's motherboard connection.
  4. Lenovo Ideapad 330-15ARR Speaker Replacement: paso 4, imagen 1 de 3 Lenovo Ideapad 330-15ARR Speaker Replacement: paso 4, imagen 2 de 3 Lenovo Ideapad 330-15ARR Speaker Replacement: paso 4, imagen 3 de 3
    • Each speaker has multiple plastic connection points - simply pull upwards and they should easily slide off of them.
    • Remove the speaker.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 190
