Saltar al contenido principal
Lenovo Ideapad 330-15ARR Fan Assembly Replacement
Qué necesitas
  1. Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Lower Case: paso 1, imagen 1 de 1
    • Remove all Phillips #0 screws securing the case to the laptop.
  2. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: paso 2, imagen 1 de 2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: paso 2, imagen 2 de 2
    • Pry all edges off of the laptop with the opening tool until the lower case releases.
    • Remove the lower case.
  3. Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Fan Assembly: paso 3, imagen 1 de 2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement, Fan Assembly: paso 3, imagen 2 de 2
    • Unscrew all three captive screws attaching the heat sink to the motherboard with a Phillips #0 screwdriver.
    • These screws stay attached to the heatsink, so do not attempt to remove them.
  4. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: paso 4, imagen 1 de 2 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: paso 4, imagen 2 de 2
    • Remove the three Phillips #0 screws securing the fan assembly.
  5. Lenovo Ideapad 330-15ARR Fan Assembly Replacement: paso 5, imagen 1 de 3 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: paso 5, imagen 2 de 3 Lenovo Ideapad 330-15ARR Fan Assembly Replacement: paso 5, imagen 3 de 3
    • Take the wires in your hand, and firmly but gently pull it out of its port.
    • Lift the fan assembly out of the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 22
Todo El Tiempo: 365
