Saltar al contenido principal
Lenovo Ideapad 320-17IKB Speakers Replacement
Qué necesitas
  1. Lenovo Ideapad 320-17IKB Speakers Replacement, Back Panel: paso 1, imagen 1 de 1
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB Speakers Replacement: paso 2, imagen 1 de 2 Lenovo Ideapad 320-17IKB Speakers Replacement: paso 2, imagen 2 de 2
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB Speakers Replacement: paso 3, imagen 1 de 1
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB Speakers Replacement: paso 4, imagen 1 de 2 Lenovo Ideapad 320-17IKB Speakers Replacement: paso 4, imagen 2 de 2
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB Speakers Replacement, Battery: paso 5, imagen 1 de 2 Lenovo Ideapad 320-17IKB Speakers Replacement, Battery: paso 5, imagen 2 de 2
    • Remove five 7mm Phillips #0 screws from the battery holder.
  6. Lenovo Ideapad 320-17IKB Speakers Replacement: paso 6, imagen 1 de 2 Lenovo Ideapad 320-17IKB Speakers Replacement: paso 6, imagen 2 de 2
    • Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
    • When removing the battery, use care to keep it flat and do not open the battery because it can result in fire or explosion.
  7. Lenovo Ideapad 320-17IKB Speakers Replacement, Speakers: paso 7, imagen 1 de 2 Lenovo Ideapad 320-17IKB Speakers Replacement, Speakers: paso 7, imagen 2 de 2
    • Gently pinch the white tab and pull the speaker cable out of its socket.
    • Don't pull on the cables.
    • The speaker connector is located directly underneath the battery.
    • If you can't get the speaker cable out by hand, use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
  8. Lenovo Ideapad 320-17IKB Speakers Replacement: paso 8, imagen 1 de 3 Lenovo Ideapad 320-17IKB Speakers Replacement: paso 8, imagen 2 de 3 Lenovo Ideapad 320-17IKB Speakers Replacement: paso 8, imagen 3 de 3
    • Lift the left and right speakers up and disconnect the cables from the chassis to remove the speaker assembly from the laptop.
Conclusión
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Amy Aquije
Miembro Desde 02/08/24
85 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 51
