Introducción
This guide demonstrates how to replace the speakers of your Lenovo Ideapad 320-17IKB. The speakers are responsible for the output of external audio from the system. Whether your laptop is suffering from fuzzy sound, low volume, or just simply malfunctioning, use this guide to conduct a complete replacement of both speakers.
Before you begin this repair, turn off your laptop and unplug it from the charger.
Qué necesitas
Gently pinch the white tab and pull the speaker cable out of its socket.
If you can't get the speaker cable out by hand, use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
