Introducción
This guide will show the steps for replacing the hard drive for your Lenovo Ideapad 320-17IKB laptop. The hard drive is the memory storage system for the laptop, and contains all the laptop's applications, files, and operating system. The hard drive may need to be replaced if the laptop has difficulty starting up, is running slow due to lack of storage space, or frequently crashes when accessing applications. The hard drive may also be replaced with a solid state drive for improved performance.
Before you begin this repair, turn off your laptop and unplug it from the charger.
Qué necesitas
Disconnect the hard drive from the SATA slot by gently pulling the hard drive to the left.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
