Saltar al contenido principal
Lenovo Ideapad 320-15IAP Hard Drive Replacement
Qué necesitas
  1. Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 2 Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: paso 1, imagen 2 de 2
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back panel.
  2. Lenovo Ideapad 320-15IAP Hard Drive Replacement: paso 2, imagen 1 de 2 Lenovo Ideapad 320-15IAP Hard Drive Replacement: paso 2, imagen 2 de 2
    • Remove the CD reader with an opening tool. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Lift the cover using the opening tool on different spots along the side of the laptop.
  3. Lenovo Ideapad 320-15IAP Hard Drive Replacement: paso 3, imagen 1 de 1
    • Remove the hard drive by inserting your finger under the highlighted area, then pushing up then pulling left to remove the drive.
    • Remove the adapter from the drive, then insert the new drive into the adapter.
    • To insert the new drive, gently place it into the enclosure for the hard drive and push carefully into the SATA slot.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 50
Todo El Tiempo: 1,310
