Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lenovo Ideapad 320-15ABR Screen Replacement
Qué necesitas
  1. Lenovo Ideapad 320-15ABR Screen Replacement, Screen: paso 1, imagen 1 de 3 Lenovo Ideapad 320-15ABR Screen Replacement, Screen: paso 1, imagen 2 de 3 Lenovo Ideapad 320-15ABR Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Begin by prying off the black cover surrounding the screen by wedging the the iFixit opening tool underneath it. Work your way down until you reach the hinge cover.
    • Insert iFixit opening tool in to the hinge cover as pictured and begin slowly prying it off.
    • This will require some force, but take care not to break the hinge cover.
    • Remove the black cover.
    Pregunta a FixBot
    Agregar Comentario
  2. Lenovo Ideapad 320-15ABR Screen Replacement: paso 2, imagen 1 de 3 Lenovo Ideapad 320-15ABR Screen Replacement: paso 2, imagen 2 de 3 Lenovo Ideapad 320-15ABR Screen Replacement: paso 2, imagen 3 de 3
    • Using the Phillips #1 screwdriver, remove the four 3mm screws securing the screen, and put them on the magnetic mat so you will not misplace them.
    • Gently lift the screen out and place it facing down on the keyboard.
    Pregunta a FixBot
    Agregar Comentario
  3. Lenovo Ideapad 320-15ABR Screen Replacement: paso 3, imagen 1 de 3 Lenovo Ideapad 320-15ABR Screen Replacement: paso 3, imagen 2 de 3 Lenovo Ideapad 320-15ABR Screen Replacement: paso 3, imagen 3 de 3
    • Carefully flip the hinge securing the connector up with the opening tool.
    • Slowly work the plug out of the connector.
    • Do not pull by the the cable, as the cable is fragile.
    • Insert the plug from the replacement screen in to the connector. Make sure the connection is secure before flipping the hinge back down.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
3 personas más completaron esta guía.
1Guía Comentario
How to replace hinge for this model
Deepak Singh - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 16
Ultimos 30 días: 73
Todo El Tiempo: 5,165
