Saltar al contenido principal
Lenovo Ideapad 310-15IKB Fan Replacement
Qué necesitas
  1. Lenovo Ideapad 310-15IKB Fan Replacement, Fan: paso 1, imagen 1 de 1
    • Flip the laptop over so the back panel is facing up.
    • Remove the single 6 mm screw from the L-shaped panel using a Phillips #0 screwdriver.
  2. Lenovo Ideapad 310-15IKB Fan Replacement: paso 2, imagen 1 de 1
    • Remove the panel from the laptop.
  3. Lenovo Ideapad 310-15IKB Fan Replacement: paso 3, imagen 1 de 1
    • Gently unplug the connector for the fan from the underside by pulling it gently.
  4. Lenovo Ideapad 310-15IKB Fan Replacement: paso 4, imagen 1 de 1
    • Flip the laptop upright and open it with the screen facing you.
  5. Lenovo Ideapad 310-15IKB Fan Replacement: paso 5, imagen 1 de 1
    • Use an opening tool to remove the keyboard cover panel, exposing the motherboard and fan.
  6. Lenovo Ideapad 310-15IKB Fan Replacement: paso 6, imagen 1 de 1
    • Remove the single 3 mm screw holding the fan in place using a Phillips #0 screwdriver.
  7. Lenovo Ideapad 310-15IKB Fan Replacement: paso 7, imagen 1 de 1
    • Remove the fan by pulling it away from the motherboard and then upwards out of the laptop.
Conclusión
To reassemble your device, follow these instructions in reverse order. Be careful to align the fan screw holes in place.
Sergio Burchell
Miembro Desde 02/20/22
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 24
Todo El Tiempo: 452
