Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lenovo Ideapad 120s-14iSp Motherboard Replacement
Qué necesitas
  1. Lenovo Ideapad 120s-14iSp Motherboard Replacement, Back Cover: paso 1, imagen 1 de 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
    Pregunta a FixBot
    Agregar Comentario
  2. Lenovo Ideapad 120s-14iSp Motherboard Replacement: paso 2, imagen 1 de 1
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
    Pregunta a FixBot
    Agregar Comentario
  3. Lenovo Ideapad 120s-14iSp Motherboard Replacement, USB Daughterboard: paso 3, imagen 1 de 2 Lenovo Ideapad 120s-14iSp Motherboard Replacement, USB Daughterboard: paso 3, imagen 2 de 2
    • Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
    Pregunta a FixBot
    Agregar Comentario
  4. Lenovo Ideapad 120s-14iSp Motherboard Replacement: paso 4, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Using tweezers, disconnect the speaker on the left from the USB daugterboard.
    • Remove two 2.5 mm Phillips #0 screws from the daughterboard.
    • Remove the daughterboard from the laptop.
    Pregunta a FixBot
    Agregar Comentario
  5. Lenovo Ideapad 120s-14iSp Motherboard Replacement, Motherboard: paso 5, imagen 1 de 3 Lenovo Ideapad 120s-14iSp Motherboard Replacement, Motherboard: paso 5, imagen 2 de 3 Lenovo Ideapad 120s-14iSp Motherboard Replacement, Motherboard: paso 5, imagen 3 de 3
    • Using a spudger, disconnect the keyboard ribbon cable from the motherboard.
    • Pull on the plastic film to remove the display connection cable.
    Pregunta a FixBot
    Agregar Comentario
  6. Lenovo Ideapad 120s-14iSp Motherboard Replacement: paso 6, imagen 1 de 1
    • Using tweezers, disconnect the connections for the right speaker.
    • Using tweezers, disconnect the connections for the battery.
    • Using tweezers, disconnect the connections for the CMOS battery.
    Pregunta a FixBot
    Agregar Comentario
  7. Lenovo Ideapad 120s-14iSp Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove the wireless card by disconnecting the two antenna cables and removing the 2.5 mm Phillips #0 screw.
    Pregunta a FixBot
    Agregar Comentario
  8. Lenovo Ideapad 120s-14iSp Motherboard Replacement: paso 8, imagen 1 de 2 Lenovo Ideapad 120s-14iSp Motherboard Replacement: paso 8, imagen 2 de 2
    • Remove seven 2.5 mm Phillips #0 screws from the motherboard.
    • Slide the motherboard out of the laptop chassis.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
4 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 46
Todo El Tiempo: 3,549
