Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Lenovo Ideapad 120s-14IAP LCD Screen Replacement
Qué necesitas
  1. Lenovo Ideapad 120s-14IAP LCD Screen Replacement, LCD Screen: paso 1, imagen 1 de 1
    • Open your laptop and insert the Jimmy into the space between the plastic screen cover and the laptop back.
    • Run the Jimmy along the edge and carefully pull the cover outward as you go.
    • Once you have completely detached the screen cover from around the edges, gently pull and remove the cover.
    Pregunta a FixBot
    Agregar Comentario
  2. Lenovo Ideapad 120s-14IAP LCD Screen Replacement: paso 2, imagen 1 de 1
    • Remove four Phillips #0 screws from the corners of the LCD screen to detach the screen from the mounts.
    • The screen is still attached by an electrical connector at the bottom, so don't completely remove the screen quite yet. Be ready to catch the top, as it will want to fall forward.
    Pregunta a FixBot
    Agregar Comentario
  3. Lenovo Ideapad 120s-14IAP LCD Screen Replacement: paso 3, imagen 1 de 1
    • Lean the LCD screen forward to expose the display connection near the base.
    • Remove the display connector by placing your thumbnail under the connector latch, and gently pull the LCD screen.
    • The LCD screen can now be removed.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
2 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 32
Todo El Tiempo: 1,658
