Introducción
This guide will allow any owner of a Lenovo Ideapad 110S-11IBR to undergo the process necessary to remove and replace the screen of the device. To do so, simply follow the given steps, starting with the removal of the back panel, loosening of the screen hinges, and eventually removal of the screen. To reassemble, follow the steps in reverse order.
Qué necesitas
Use a Phillips #0 screwdriver to remove the eleven 3.7 mm screws from the bottom of the Chromebook.
2 personas más completaron esta guía.
