Saltar al contenido principal
Introducción
This is a quick guide on how to remove and replace the battery.
Partes
No se especificaron partes.
Resumen del Video
  1. Remove all 11 screws from the base of the laptop.
    • Remove all 11 screws from the base of the laptop.
  2. Once the screws have been removed, lift the base out of the laptop. You may need something pointy to pry it up.
    • Once the screws have been removed, lift the base out of the laptop. You may need something pointy to pry it up.
  3. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Next disconnect the battery Next disconnect the battery
    • Next disconnect the battery
  5. Next remove the four screws holding the battery in place.
    • Next remove the four screws holding the battery in place.
  6. And your all done. And your all done.
    • And your all done.
Conclusión
4 personas más completaron esta guía.
Nick Myers
Miembro Desde 15/04/18
383 Reputación
2 Guías creadas
YOU HAVE TO REMOVE THE KEYBOARD. First, the keyboard is glued with two sided tape so it feels like you are breaking something getting it off. It also has clips all around don't try to undo the bottom until last. Second, there are 3 screws under the keyboard that need to be removed. The third screw was hidden under a Lenovo label, thanks Lenovo. Thirdly, there is no need to disconnect the keyboard harness.
panellockout - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 8
Últimos 7 Días: 78
Últimos 30 Días: 374
Todo El Tiempo: 3,128
