Saltar al contenido principal
Lenovo IdeaTab S2109A-F Battery Replacement
Qué necesitas
  1. Lenovo IdeaTab S2109A-F Battery Replacement, Battery: paso 1, imagen 1 de 2 Lenovo IdeaTab S2109A-F Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Battery Replacement: paso 2, imagen 1 de 2 Lenovo IdeaTab S2109A-F Battery Replacement: paso 2, imagen 2 de 2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Battery Replacement: paso 3, imagen 1 de 1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
Conclusión
Una persona más ha completado esta guía.
Caelen
Miembro Desde 01/16/15
228 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 17-3, Watkins Winter 2015 Miembro de USF Tampa, Team 17-3, Watkins Winter 2015
USFT-WATKINS-W15S17G3
4 Miembros
10 Guías creadas
2 comentarios
Folks this is not easy! The first thing that happened, my screen broke. Then it took about thirty minutes to finally get the back off and the on-off swithch was damaged. Take it to a shop and let them do the damage, then its up to them to pay for it or replace it. I’m now out a s2109 Lenovo tablet because the instructions said easy. Maybe his was. This one sure as heck was not!!
jangoodman - Contestar
Theres some screws missing from the directions, under the speakers and in a hole along one side. Tiny torx on the side.
Devin Holland - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 1,533
