Saltar al contenido principal
Lenovo IdeaTab A2109 Digital Board Replacement
Qué necesitas
  1. Lenovo IdeaTab A2109 Digital Board Replacement, Digital Board: paso 1, imagen 1 de 1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller plastic cover that runs across the top of the device.
    • Wedge the blue opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 Digital Board Replacement: paso 2, imagen 1 de 2 Lenovo IdeaTab A2109 Digital Board Replacement: paso 2, imagen 2 de 2
    • Remove the following two screws:
    • M3.0 x 3.0 mm #00 phillips screws (black)
  3. Lenovo IdeaTab A2109 Digital Board Replacement: paso 3, imagen 1 de 3 Lenovo IdeaTab A2109 Digital Board Replacement: paso 3, imagen 2 de 3 Lenovo IdeaTab A2109 Digital Board Replacement: paso 3, imagen 3 de 3
    • Once it is unscrewed, remove the rear cover
    • This may take a little force to get off but with enough force it should pop right off
    • Use a blue opening tool to pry it open
    • Slide the tool to one corner then grab another tool and slide it to the opposite corner
    • Pull the cover up and it will come off
  4. Lenovo IdeaTab A2109 Digital Board Replacement: paso 4, imagen 1 de 2 Lenovo IdeaTab A2109 Digital Board Replacement: paso 4, imagen 2 de 2
    • Use the tweezer tool to flip up the three small plastic locks attached to the digital board.
    • Then, slide newly exposed ribbons out.
  5. Lenovo IdeaTab A2109 Digital Board Replacement: paso 5, imagen 1 de 2 Lenovo IdeaTab A2109 Digital Board Replacement: paso 5, imagen 2 de 2
    • M5.3 x 1.75 mm #00 phillips screws (silver)
  6. Lenovo IdeaTab A2109 Digital Board Replacement: paso 6, imagen 1 de 1
    • Once it is unscrewed, use the tweezer tool to pull the digital board straight out.
Conclusión
4 personas más completaron esta guía.
Brian
Miembro Desde 04/22/14
565 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 7-19, Regan Spring 2014 Miembro de Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 3,054
