Saltar al contenido principal
Lenovo IdeaPad Z570 Screen Replacement
Qué necesitas
  1. Lenovo IdeaPad Z570 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Screen Replacement: paso 2, imagen 1 de 1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Screen Replacement: paso 3, imagen 1 de 1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Screen Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad Z570 Screen Replacement: paso 4, imagen 2 de 2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Screen Replacement, Screen: paso 5, imagen 1 de 1
    • Open up the laptop with the screen facing you.
  6. Lenovo IdeaPad Z570 Screen Replacement: paso 6, imagen 1 de 2 Lenovo IdeaPad Z570 Screen Replacement: paso 6, imagen 2 de 2
    • Remove the two rubber square screw covers located in the left and right lower hand corners of the screen.
  7. Lenovo IdeaPad Z570 Screen Replacement: paso 7, imagen 1 de 2 Lenovo IdeaPad Z570 Screen Replacement: paso 7, imagen 2 de 2
    • Unscrew the two 4 mm screws behind the two rubber screw covers using the Phillips #0 screwdriver.
  8. Lenovo IdeaPad Z570 Screen Replacement: paso 8, imagen 1 de 2 Lenovo IdeaPad Z570 Screen Replacement: paso 8, imagen 2 de 2
    • Using the opening tool, pry open the plastic screen border, beginning with the upper right hand corner then working your way around.
    • Pry off the screen cover from the device.
  9. Lenovo IdeaPad Z570 Screen Replacement: paso 9, imagen 1 de 2 Lenovo IdeaPad Z570 Screen Replacement: paso 9, imagen 2 de 2
    • Remove the two 2 mm screws at the top two corners of the screen using the Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Screen Replacement: paso 10, imagen 1 de 2 Lenovo IdeaPad Z570 Screen Replacement: paso 10, imagen 2 de 2
    • Loosen the four 2 mm screws located at the bottom corners of the screen.
    • These screws cannot be removed.
  11. Lenovo IdeaPad Z570 Screen Replacement: paso 11, imagen 1 de 3 Lenovo IdeaPad Z570 Screen Replacement: paso 11, imagen 2 de 3 Lenovo IdeaPad Z570 Screen Replacement: paso 11, imagen 3 de 3
    • Tilt the screen forward gently.
    • Remove four 3 mm screws on the sides of the brackets holding the screen (two on the left side and two on the right side) using the Phillips #0 screwdriver.
  12. Lenovo IdeaPad Z570 Screen Replacement: paso 12, imagen 1 de 1
    • Lean the LCD screen face-down on the keyboard gently.
  13. Lenovo IdeaPad Z570 Screen Replacement: paso 13, imagen 1 de 3 Lenovo IdeaPad Z570 Screen Replacement: paso 13, imagen 2 de 3 Lenovo IdeaPad Z570 Screen Replacement: paso 13, imagen 3 de 3
    • Gently remove the adhesive covering surrounding the wires that’s connected to the back of the screen.
    • Disconnect the plug from the connection terminal.
    • Remove the screen completely.
Conclusión
Una persona más ha completado esta guía.
Daniel Lopes
Miembro Desde 03/08/19
610 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 1,034
