Saltar al contenido principal
Lenovo IdeaPad Z570 Keyboard Replacement
Qué necesitas
  1. Lenovo IdeaPad Z570 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Keyboard Replacement: paso 2, imagen 1 de 1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Keyboard Replacement: paso 3, imagen 1 de 1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Keyboard Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad Z570 Keyboard Replacement: paso 4, imagen 2 de 2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Keyboard Replacement, Disc Drive: paso 5, imagen 1 de 1
    • Place the laptop face down with the battery slot facing away from you.
  6. Lenovo IdeaPad Z570 Keyboard Replacement: paso 6, imagen 1 de 2 Lenovo IdeaPad Z570 Keyboard Replacement: paso 6, imagen 2 de 2
    • Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
    • These screws cannot be removed from the device.
    • Remove the back panel from the device.
  7. Lenovo IdeaPad Z570 Keyboard Replacement: paso 7, imagen 1 de 2 Lenovo IdeaPad Z570 Keyboard Replacement: paso 7, imagen 2 de 2
    • Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
  8. Lenovo IdeaPad Z570 Keyboard Replacement: paso 8, imagen 1 de 2 Lenovo IdeaPad Z570 Keyboard Replacement: paso 8, imagen 2 de 2
    • Gently remove the disc drive from the left hand side of the laptop.
  9. Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: paso 9, imagen 1 de 3 Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: paso 9, imagen 2 de 3 Lenovo IdeaPad Z570 Keyboard Replacement, Keyboard: paso 9, imagen 3 de 3
    • Remove the three 12mm screws found near these symbols with a Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Keyboard Replacement: paso 10, imagen 1 de 1
    • Orient the laptop at a 90 degree angle with the keyboard being vertical and the screen horizontal to the surface you are working on.
  11. Lenovo IdeaPad Z570 Keyboard Replacement: paso 11, imagen 1 de 2 Lenovo IdeaPad Z570 Keyboard Replacement: paso 11, imagen 2 de 2
    • Pry the keyboard off staring from the corner where the “esc”” key is located using an opening tool.
    • Now orient the laptop in the standard position and take off the keyboard.
  12. Lenovo IdeaPad Z570 Keyboard Replacement: paso 12, imagen 1 de 3 Lenovo IdeaPad Z570 Keyboard Replacement: paso 12, imagen 2 de 3 Lenovo IdeaPad Z570 Keyboard Replacement: paso 12, imagen 3 de 3
    • At the terminal block, flip the black switch on the terminal up.
  13. Lenovo IdeaPad Z570 Keyboard Replacement: paso 13, imagen 1 de 2 Lenovo IdeaPad Z570 Keyboard Replacement: paso 13, imagen 2 de 2
    • Pull the keyboard out from the terminal block.
Conclusión
2 personas más completaron esta guía.
Mya DeSantos
Miembro Desde 03/18/19
318 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 18
Todo El Tiempo: 1,196
