Saltar al contenido principal
Lenovo IdeaPad Z570 Charging Port Replacement
Qué necesitas
  1. Lenovo IdeaPad Z570 Charging Port Replacement, Battery: paso 1, imagen 1 de 1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Charging Port Replacement: paso 2, imagen 1 de 1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Charging Port Replacement: paso 3, imagen 1 de 1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Charging Port Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: paso 4, imagen 2 de 2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Charging Port Replacement, Disc Drive: paso 5, imagen 1 de 1
    • Place the laptop face down with the battery slot facing away from you.
  6. Lenovo IdeaPad Z570 Charging Port Replacement: paso 6, imagen 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: paso 6, imagen 2 de 2
    • Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
    • These screws cannot be removed from the device.
    • Remove the back panel from the device.
  7. Lenovo IdeaPad Z570 Charging Port Replacement: paso 7, imagen 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: paso 7, imagen 2 de 2
    • Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
  8. Lenovo IdeaPad Z570 Charging Port Replacement: paso 8, imagen 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: paso 8, imagen 2 de 2
    • Gently remove the disc drive from the left hand side of the laptop.
  9. Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: paso 9, imagen 1 de 3 Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: paso 9, imagen 2 de 3 Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: paso 9, imagen 3 de 3
    • Remove the three 12mm screws found near these symbols with a Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Charging Port Replacement: paso 10, imagen 1 de 1
    • Orient the laptop at a 90 degree angle with the keyboard being vertical and the screen horizontal to the surface you are working on.
  11. Lenovo IdeaPad Z570 Charging Port Replacement: paso 11, imagen 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: paso 11, imagen 2 de 2
    • Pry the keyboard off staring from the corner where the “esc”” key is located using an opening tool.
    • Now orient the laptop in the standard position and take off the keyboard.
  12. Lenovo IdeaPad Z570 Charging Port Replacement: paso 12, imagen 1 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: paso 12, imagen 2 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: paso 12, imagen 3 de 3
    • At the terminal block, flip the black switch on the terminal up.
  13. Lenovo IdeaPad Z570 Charging Port Replacement: paso 13, imagen 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: paso 13, imagen 2 de 2
    • Pull the keyboard out from the terminal block.
  14. Lenovo IdeaPad Z570 Charging Port Replacement, Charging Port: paso 14, imagen 1 de 1
    • Place the laptop on the backside with the battery facing away from you.
    • Remove the eleven 7 mm screws located around the edge of the backside of the laptop using the Phillips #0 screwdriver.
  15. Lenovo IdeaPad Z570 Charging Port Replacement: paso 15, imagen 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: paso 15, imagen 2 de 2
    • Remove the two 3 mm screws located in the battery slot using the Phillips #0 screwdriver.
    • Orientate the laptop back to its original position.
  16. Lenovo IdeaPad Z570 Charging Port Replacement: paso 16, imagen 1 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: paso 16, imagen 2 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: paso 16, imagen 3 de 3
    • There are three connection strips similar to the one in guide three.
    • Remove the three connection strips in the same manner as the keyboard replacement guide.
  17. Lenovo IdeaPad Z570 Charging Port Replacement: paso 17, imagen 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: paso 17, imagen 2 de 2
    • Remove the two 7mm screws found on the right side of the silver plating on the laptop using the Phillips #0 screwdriver.
  18. Lenovo IdeaPad Z570 Charging Port Replacement: paso 18, imagen 1 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: paso 18, imagen 2 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: paso 18, imagen 3 de 3
    • Wedge the opening tool between the ethernet jack and the speaker to pry of the front plate of the laptop.
  19. Lenovo IdeaPad Z570 Charging Port Replacement: paso 19, imagen 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: paso 19, imagen 2 de 2
    • Remove the one 7 mm screw located at the top left corner of the laptop near the charging port using the Phillips #0 screwdriver.
  20. Lenovo IdeaPad Z570 Charging Port Replacement: paso 20, imagen 1 de 2 Lenovo IdeaPad Z570 Charging Port Replacement: paso 20, imagen 2 de 2
    • There are two connection terminals on the upper right hand corner of the fan.
    • Remove the connection terminal marked with a blue stripe.
  21. Lenovo IdeaPad Z570 Charging Port Replacement: paso 21, imagen 1 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: paso 21, imagen 2 de 3 Lenovo IdeaPad Z570 Charging Port Replacement: paso 21, imagen 3 de 3
    • Lift the metal plate enough to wedge your index finger and thumb to grip the charger port.
    • Remove the charging port from the device.
Conclusión
Mya DeSantos
Miembro Desde 03/18/19
318 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 34
Todo El Tiempo: 1,637
