Saltar al contenido principal
Lenovo IdeaPad Y700-15ACZ Battery Replacement
Qué necesitas
  1. Lenovo IdeaPad Y700-15ACZ Battery Replacement, Battery: paso 1, imagen 1 de 2 Lenovo IdeaPad Y700-15ACZ Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Flip the laptop upside down so that the bottom is facing up.
    • Using the #0 Phillips screwdriver, unscrew the eleven Phillips #0 screws (two 1.5 mm screws, one 0.3 mm screw, and eight 0.5 mm screws) that attach the cover to the laptop.
  2. Lenovo IdeaPad Y700-15ACZ Battery Replacement: paso 2, imagen 1 de 1
    • After removing the eleven Phillips #0 screws (two 1.5 mm screws, one 0.3 mm screw, and eight 0.5 mm screws), use the Jimmy to pop up the cover and remove it from the laptop.
  3. Lenovo IdeaPad Y700-15ACZ Battery Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad Y700-15ACZ Battery Replacement: paso 3, imagen 2 de 2
    • Find the battery connection above the battery.
    • Unplug the battery from the motherboard.
  4. Lenovo IdeaPad Y700-15ACZ Battery Replacement: paso 4, imagen 1 de 3 Lenovo IdeaPad Y700-15ACZ Battery Replacement: paso 4, imagen 2 de 3 Lenovo IdeaPad Y700-15ACZ Battery Replacement: paso 4, imagen 3 de 3
    • Unscrew the 0.5 mm screws from battery connected to the motherboard with the #0 Philips screwdriver.
    • Gently lift the battery from the laptop and replace the battery.
Conclusión
Kevin
Miembro Desde 09/28/22
351 Reputación
3 Guías creadas
Equipo
CSU Los Angeles, Team 6-6, Adachi Fall 2022 Miembro de CSU Los Angeles, Team 6-6, Adachi Fall 2022
CSULA-ADACHI-F22S6G6
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 38
Todo El Tiempo: 797
