Saltar al contenido principal
Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement
Qué necesitas
  1. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement, Wi-Fi Card: paso 1, imagen 1 de 1
    • Make sure the laptop is powered off and disconnected from the charger.
    • Flip the laptop upside down so that the bottom faces up.
  2. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: paso 2, imagen 1 de 1
    • Place your thumbs on each side of the laptop and slide the tabs into the unlock position.
  3. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: paso 3, imagen 1 de 1
    • Once tabs are in the unlock position, carefully slide the battery out of the compartment.
  4. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: paso 4, imagen 1 de 1
    • Use a Phillips #0 screwdriver to unscrew and remove the two 8 mm screws (highlighted in red) that secure the back panel in place.
  5. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: paso 5, imagen 1 de 1
    • Gently slide & pull the panel off the device.
  6. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: paso 6, imagen 1 de 2 Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: paso 6, imagen 2 de 2
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws that secure the Wi-Fi card in place.
  7. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: paso 7, imagen 1 de 1
    • Gently unplug the two coaxial antenna cables clasped to the Wi-Fi card.
  8. Lenovo IdeaPad Y580-2099 Wi-Fi Card Replacement: paso 8, imagen 1 de 1
    • Gently remove the old Wi-Fi card from the device.
Conclusión
Una persona más ha completado esta guía.
Jeryn Fast
Miembro Desde 04/12/22
421 Reputación
3 Guías creadas
Equipo
IUPUI, Team 1-1, Beck Spring 2022 Miembro de IUPUI, Team 1-1, Beck Spring 2022
IUPUI-BECK-S22S1G1
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 5
Ultimos 30 días: 12
Todo El Tiempo: 288
