Saltar al contenido principal
Lenovo IdeaPad Y410p Screen Replacement
Qué necesitas
  1. Lenovo IdeaPad Y410p Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Screen Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad Y410p Screen Replacement: paso 2, imagen 2 de 2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Screen Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad Y410p Screen Replacement: paso 3, imagen 2 de 2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Screen Replacement, Screen: paso 4, imagen 1 de 2 Lenovo IdeaPad Y410p Screen Replacement, Screen: paso 4, imagen 2 de 2
    • Using the metal spudger, pry the screen cover off from all sides.
    • Carefully lift the screen cover up and outwards.
    • Place the screen cover aside.
  5. Lenovo IdeaPad Y410p Screen Replacement: paso 5, imagen 1 de 3 Lenovo IdeaPad Y410p Screen Replacement: paso 5, imagen 2 de 3 Lenovo IdeaPad Y410p Screen Replacement: paso 5, imagen 3 de 3
    • Using the Phillips #0 screwdriver, remove the four 8mm screws from each corner of the screen.
    • Carefully lift the screen up and place it face down on the keyboard.
    • A thick cord connects the bottom of the screen to the computer. Do not tug or remove this cord from the computer.
  6. Lenovo IdeaPad Y410p Screen Replacement: paso 6, imagen 1 de 2 Lenovo IdeaPad Y410p Screen Replacement: paso 6, imagen 2 de 2
    • Remove the adhesive tape from the small rectangular connector at the bottom of the screen.
    • Carefully pull the wire connector from the screen connector.
    • Remove the screen.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 7
Todo El Tiempo: 366
