Saltar al contenido principal
Lenovo IdeaPad Y410p Ram Replacement
Qué necesitas
  1. Lenovo IdeaPad Y410p Ram Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Ram Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad Y410p Ram Replacement: paso 2, imagen 2 de 2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Ram Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad Y410p Ram Replacement: paso 3, imagen 2 de 2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Ram Replacement, Ram: paso 4, imagen 1 de 3 Lenovo IdeaPad Y410p Ram Replacement, Ram: paso 4, imagen 2 de 3 Lenovo IdeaPad Y410p Ram Replacement, Ram: paso 4, imagen 3 de 3
    • Using the Phillips #0 screwdriver remove the eight 8mm screws that fasten the bottom cover.
    • Lift the bottom cover off using a metal spudger and set it aside.
  5. Lenovo IdeaPad Y410p Ram Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad Y410p Ram Replacement: paso 5, imagen 2 de 2
    • Simultaneously pull apart both clips that are holding the RAM module down.
    • When the RAM module is released carefully pull it out.
  6. Lenovo IdeaPad Y410p Ram Replacement: paso 6, imagen 1 de 2 Lenovo IdeaPad Y410p Ram Replacement: paso 6, imagen 2 de 2
    • There is a second ram module under the first one.
    • Repeat Step 5 with lower Ram module.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 825
