Saltar al contenido principal
Lenovo IdeaPad Y410p Keyboard Replacement
Qué necesitas
  1. Lenovo IdeaPad Y410p Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Keyboard Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad Y410p Keyboard Replacement: paso 2, imagen 2 de 2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Keyboard Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad Y410p Keyboard Replacement: paso 3, imagen 2 de 2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Keyboard Replacement, Keyboard: paso 4, imagen 1 de 2 Lenovo IdeaPad Y410p Keyboard Replacement, Keyboard: paso 4, imagen 2 de 2
    • Power off your laptop.
    • Use a metal spudger to loosen the frame of the keyboard by running it under the edges of the keyboard as shown.
    • After loosening the keyboard frame, you should be able to gently lift up the keyboard.
  5. Lenovo IdeaPad Y410p Keyboard Replacement: paso 5, imagen 1 de 3 Lenovo IdeaPad Y410p Keyboard Replacement: paso 5, imagen 2 de 3 Lenovo IdeaPad Y410p Keyboard Replacement: paso 5, imagen 3 de 3
    • Be careful when lifting the keyboard so that you do not damage the ribbon cable connector.
    • Detach the ribbon cables from the latches shown.
Conclusión
2 personas más completaron esta guía.
2 comentarios
Terrible guide - completely fails to point out the two screws that hold the keyboard down underneath the bottom casing. Bent my keyboard thanks to this.
Dragon - Contestar
Awful guide. Wish I'd seen the other comment before I also ruined my keyboard. Thought it popped out, but there's 2 screws under the bottom case that hold it (remove!) … bent the keyboard frame and ripped the screw tabs off. Was just trying to clean it. Now it needs total replacement.
How is this article reportable?
Nateb - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 993
