Saltar al contenido principal
Lenovo IdeaPad Y400 Optical Drive Replacement
  1. Lenovo IdeaPad Y400 Optical Drive Replacement, Battery: paso 1, imagen 1 de 3 Lenovo IdeaPad Y400 Optical Drive Replacement, Battery: paso 1, imagen 2 de 3 Lenovo IdeaPad Y400 Optical Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure the laptop is upside down, then turn the laptop so that the battery is facing you. Now that the battery is facing you, there will be two locks, one on the left and one on the right.
    • Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red.
  2. Lenovo IdeaPad Y400 Optical Drive Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad Y400 Optical Drive Replacement: paso 2, imagen 2 de 2
    • Unlike the first lock, the left lock does not stay in place. You will need to hold it in place as you take the battery out.
    • Slide the second (left) lock to the left and hold it there.
  3. Lenovo IdeaPad Y400 Optical Drive Replacement: paso 3, imagen 1 de 1
    • Gently pull the battery out.
  4. Lenovo IdeaPad Y400 Optical Drive Replacement, Optical Drive: paso 4, imagen 1 de 2 Lenovo IdeaPad Y400 Optical Drive Replacement, Optical Drive: paso 4, imagen 2 de 2
    • Move the lock down until you see red and hear a slight click.
  5. Lenovo IdeaPad Y400 Optical Drive Replacement: paso 5, imagen 1 de 3 Lenovo IdeaPad Y400 Optical Drive Replacement: paso 5, imagen 2 de 3 Lenovo IdeaPad Y400 Optical Drive Replacement: paso 5, imagen 3 de 3
    • Hold this lock down while removing the optical drive.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 231
