Saltar al contenido principal
Lenovo IdeaPad Y400 Battery Replacement
  1. Lenovo IdeaPad Y400 Battery Replacement, Battery: paso 1, imagen 1 de 3 Lenovo IdeaPad Y400 Battery Replacement, Battery: paso 1, imagen 2 de 3 Lenovo IdeaPad Y400 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Make sure the laptop is upside down, then turn the laptop so that the battery is facing you. Now that the battery is facing you, there will be two locks, one on the left and one on the right.
    • Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red.
  2. Lenovo IdeaPad Y400 Battery Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad Y400 Battery Replacement: paso 2, imagen 2 de 2
    • Unlike the first lock, the left lock does not stay in place. You will need to hold it in place as you take the battery out.
    • Slide the second (left) lock to the left and hold it there.
  3. Lenovo IdeaPad Y400 Battery Replacement: paso 3, imagen 1 de 1
    • Gently pull the battery out.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 195
