Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
Use this guide to remove the back panel of your device. This guide will show you how to remove the back panel in order to remove other parts of the laptop.
Partes
No se especificaron partes.
  1. Make sure the laptop is upside down, then turn the laptop so that the battery is facing you. Now that the battery is facing you, there will be two locks, one on the left and one on the right. Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red. Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red.
    • Make sure the laptop is upside down, then turn the laptop so that the battery is facing you. Now that the battery is facing you, there will be two locks, one on the left and one on the right.
    • Slide the lock to the right until you can hear a "click". Once you hear this click, you should be able to see the color red.
  2. Unlike the first lock, the left lock does not stay in place. You will need to hold it in place as you take the battery out. Slide the second (left) lock to the left and hold it there.
    • Unlike the first lock, the left lock does not stay in place. You will need to hold it in place as you take the battery out.
    • Slide the second (left) lock to the left and hold it there.
  3. Kit de Destornilladores Manta
    112 bits for every fix.
    Upgrade Your Toolbox
  4. Gently pull the battery out.
    • Gently pull the battery out.
  5. Remove the eight 9mm screws with a Phillips #0 screwdriver.
    • Remove the eight 9mm screws with a Phillips #0 screwdriver.
  6. Use the plastic opening tool to remove the back panel from the device. Be careful not to force the back off, as you may break the clips keeping it down. Be careful not to force the back off, as you may break the clips keeping it down.
    • Use the plastic opening tool to remove the back panel from the device.
    • Be careful not to force the back off, as you may break the clips keeping it down.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 157
