Saltar al contenido principal
Lenovo IdeaPad U530 Touch Network Adapter Replacement
Qué necesitas
  1. Lenovo IdeaPad U530 Touch Network Adapter Replacement, Network Adapter: paso 1, imagen 1 de 3 Lenovo IdeaPad U530 Touch Network Adapter Replacement, Network Adapter: paso 1, imagen 2 de 3 Lenovo IdeaPad U530 Touch Network Adapter Replacement, Network Adapter: paso 1, imagen 3 de 3
    • Remove all of the screws on the back panel with a Phillips #000 screwdriver.
    • Turn over the device and remove the two screws on the outside of the hinges.
  2. Lenovo IdeaPad U530 Touch Network Adapter Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad U530 Touch Network Adapter Replacement: paso 2, imagen 2 de 2
    • Use a pry tool or iFixIt Opening tool to separate the back panel from the device.
    • Lift the back panel straight up to remove.
  3. Lenovo IdeaPad U530 Touch Network Adapter Replacement: paso 3, imagen 1 de 3 Lenovo IdeaPad U530 Touch Network Adapter Replacement: paso 3, imagen 2 de 3 Lenovo IdeaPad U530 Touch Network Adapter Replacement: paso 3, imagen 3 de 3
    • Remove the black and white wires that attach the fan to the network adapter.
  4. Lenovo IdeaPad U530 Touch Network Adapter Replacement: paso 4, imagen 1 de 2 Lenovo IdeaPad U530 Touch Network Adapter Replacement: paso 4, imagen 2 de 2
    • Remove the two screws attaching the network adapter to the motherboard.
    • Remove the network adapter by sliding it down out of its connector.
Conclusión
Rebekah Harmon
Miembro Desde 01/23/18
108 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 397
