Saltar al contenido principal
Lenovo IdeaPad U450 Screen Replacement
Qué necesitas
  1. Lenovo IdeaPad U450 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off and unplug your laptop to prevent the risk of electrocution.
    • Turn your laptop over so that the bottom is face up.
  2. Lenovo IdeaPad U450 Screen Replacement: paso 2, imagen 1 de 1
    • On the top left of the laptop there is a switch. Make sure it's pushed in the unlocked position.
  3. Lenovo IdeaPad U450 Screen Replacement: paso 3, imagen 1 de 1
    • Locate the switch collinear with the last one and move the switch to an unlocked position.
  4. Lenovo IdeaPad U450 Screen Replacement: paso 4, imagen 1 de 1
    • Remove the unlocked battery.
  5. Lenovo IdeaPad U450 Screen Replacement, Screen: paso 5, imagen 1 de 1
    • Open the laptop.
  6. Lenovo IdeaPad U450 Screen Replacement: paso 6, imagen 1 de 1
    • Remove the four 7mm phillips head screws in the corners of the screen with a Phillips #00 Screwdriver.
  7. Lenovo IdeaPad U450 Screen Replacement: paso 7, imagen 1 de 1
    • Pry the screen out of the tabs with a spudger.
  8. Lenovo IdeaPad U450 Screen Replacement: paso 8, imagen 1 de 1
    • Remove the four 7mm phillips head screws located beneath the screen.
  9. Lenovo IdeaPad U450 Screen Replacement: paso 9, imagen 1 de 1
    • Pop out the connector that links the screen to the motherboard.
  10. Lenovo IdeaPad U450 Screen Replacement: paso 10, imagen 1 de 1
    • Pop the new screen into the connector.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 227
