Saltar al contenido principal
Lenovo IdeaPad U450 Keyboard Replacement
Qué necesitas
  1. Lenovo IdeaPad U450 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off and unplug your laptop to prevent the risk of electrocution.
    • Turn your laptop over so that the bottom is face up.
  2. Lenovo IdeaPad U450 Keyboard Replacement: paso 2, imagen 1 de 1
    • On the top left of the laptop there is a switch. Make sure it's pushed in the unlocked position.
  3. Lenovo IdeaPad U450 Keyboard Replacement: paso 3, imagen 1 de 1
    • Locate the switch collinear with the last one and move the switch to an unlocked position.
  4. Lenovo IdeaPad U450 Keyboard Replacement: paso 4, imagen 1 de 1
    • Remove the unlocked battery.
  5. Lenovo IdeaPad U450 Keyboard Replacement, Keyboard: paso 5, imagen 1 de 1
    • Flip the laptop so it's facing upwards.
  6. Lenovo IdeaPad U450 Keyboard Replacement: paso 6, imagen 1 de 1
    • Open the laptop.
  7. Lenovo IdeaPad U450 Keyboard Replacement: paso 7, imagen 1 de 1
    • Press the most northern region above F6 and F7 until a bit of your keyboard pops out.
  8. Lenovo IdeaPad U450 Keyboard Replacement: paso 8, imagen 1 de 1
    • Use the spudger to pry the top of the keyboard out.
  9. Lenovo IdeaPad U450 Keyboard Replacement: paso 9, imagen 1 de 1
    • Disconnect the wire connecting to keyboard to the laptop.
  10. Lenovo IdeaPad U450 Keyboard Replacement: paso 10, imagen 1 de 1
    • Remove the keyboard
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 288
