Saltar al contenido principal
Lenovo IdeaPad U450 Fan Replacement
Qué necesitas
  1. Lenovo IdeaPad U450 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off and unplug your laptop to prevent the risk of electrocution.
    • Turn your laptop over so that the bottom is face up.
  2. Lenovo IdeaPad U450 Fan Replacement: paso 2, imagen 1 de 1
    • On the top left of the laptop there is a switch. Make sure it's pushed in the unlocked position.
  3. Lenovo IdeaPad U450 Fan Replacement: paso 3, imagen 1 de 1
    • Locate the switch collinear with the last one and move the switch to an unlocked position.
  4. Lenovo IdeaPad U450 Fan Replacement: paso 4, imagen 1 de 1
    • Remove the unlocked battery.
  5. Lenovo IdeaPad U450 Fan Replacement, Top Panel: paso 5, imagen 1 de 1
    • Turn the laptop over so that the bottom is facing up.
  6. Lenovo IdeaPad U450 Fan Replacement: paso 6, imagen 1 de 1
    • Remove all 7mm phillips head screws using the Phillips #00 screwdriver.
  7. Lenovo IdeaPad U450 Fan Replacement: paso 7, imagen 1 de 1
    • Turn the laptop over again and open the laptop.
  8. Lenovo IdeaPad U450 Fan Replacement: paso 8, imagen 1 de 1
    • Gently lift up the top panel utilizing the hole where the battery would be.
    • Keyboard ribbon cable is still connected. Flip the ZIF connector up and remove the ribbon cable.
  9. Lenovo IdeaPad U450 Fan Replacement: paso 9, imagen 1 de 1
    • Disconnect any wires that are connected to the top panel from the bottom of the laptop.
  10. Lenovo IdeaPad U450 Fan Replacement, Fan: paso 10, imagen 1 de 1
    • Unplug the bundled fan connector from the motherboard.
  11. Lenovo IdeaPad U450 Fan Replacement: paso 11, imagen 1 de 1
    • Unscrew all screws that hold the fan down using the Phillips #00 screwdriver.
  12. Lenovo IdeaPad U450 Fan Replacement: paso 12, imagen 1 de 1
    • Remove the fan from the slot.
Conclusión
Una persona más ha completado esta guía.
Anna Church
Miembro Desde 03/21/17
146 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 402
