Saltar al contenido principal
Lenovo IdeaPad U430 Touch Trackpad Replacement
Qué necesitas
  1. Lenovo IdeaPad U430 Touch Trackpad Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Trackpad Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad U430 Touch Trackpad Replacement: paso 3, imagen 2 de 2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Trackpad Replacement, Battery: paso 4, imagen 1 de 2 Lenovo IdeaPad U430 Touch Trackpad Replacement, Battery: paso 4, imagen 2 de 2
    • Remove the five 2.8 mm #1 Phillips head screws that hold down the battery pack.
  4. Lenovo IdeaPad U430 Touch Trackpad Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad U430 Touch Trackpad Replacement: paso 5, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using a combination of plastic opening tool and spudger, press in on the clips on the sides of the battery connector and push the connector out
    • When you get the connector out far enough, grab behind the connector tabs with tweezers and wiggle the connector the rest of the way out.
    • The battery connector is very tight fitting, you may need to use a metal spudger in order to get the connector out far enough.
  5. Lenovo IdeaPad U430 Touch Trackpad Replacement: paso 6, imagen 1 de 2 Lenovo IdeaPad U430 Touch Trackpad Replacement: paso 6, imagen 2 de 2
    • Once the battery is disconnected, lift up on the front of the battery and remove it from the laptop body.
  6. Lenovo IdeaPad U430 Touch Trackpad Replacement, Trackpad: paso 7, imagen 1 de 2 Lenovo IdeaPad U430 Touch Trackpad Replacement, Trackpad: paso 7, imagen 2 de 2
    • Remove the two 2.8 mm screws attached to the trackpad using the Phillips #1 screwdriver.
    • Detach the zif ribbon labeled "TP" and "MB" at the "MB" end.
  7. Lenovo IdeaPad U430 Touch Trackpad Replacement: paso 8, imagen 1 de 1
    • Grasping one of the screw brackets, gently lift the trackpad out of its frame.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 310
