Saltar al contenido principal
Lenovo IdeaPad U430 Touch Speaker Replacement
Qué necesitas
  1. Lenovo IdeaPad U430 Touch Speaker Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Speaker Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad U430 Touch Speaker Replacement: paso 3, imagen 2 de 2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Speaker Replacement, Speaker: paso 4, imagen 1 de 1
    • Disconnect the speaker cable connectors from the motherboard and/or USB board.
  4. Lenovo IdeaPad U430 Touch Speaker Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad U430 Touch Speaker Replacement: paso 5, imagen 2 de 2
    • Unscrew the two 6.5mm screws from each speaker with a PH1 Phillips head screwdriver.
  5. Lenovo IdeaPad U430 Touch Speaker Replacement: paso 6, imagen 1 de 2 Lenovo IdeaPad U430 Touch Speaker Replacement: paso 6, imagen 2 de 2
    • Remove and replace the speaker.
Conclusión
Patrick Ripkey
Miembro Desde 02/28/17
627 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S2-G6, Nance Spring 2017 Miembro de USF Tampa, Team S2-G6, Nance Spring 2017
USFT-NANCE-S17S2G6
3 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 567
