Introducción
This guide will take 5 minutes and will require you to follow a prerequisite guide on how to remove the back cover. The solid state replacement will require a Phillips #1 screwdriver and a metal spudger.
Qué necesitas
Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
Use a Phillips #1 screwdriver to remove the 3 mm screw holding the SSD in place.
Una persona más ha completado esta guía.
