Saltar al contenido principal
Lenovo IdeaPad U410 Screen Replacement
Qué necesitas
  1. Lenovo IdeaPad U410 Screen Replacement, Screen: paso 1, imagen 1 de 2 Lenovo IdeaPad U410 Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Make sure your laptop is turned off before disassembling.
    • Power off the laptop.
    • Using the metal spudger, gently pry off the black trim around the screen.
    • Metal spudger can be used, but using your hand will prevent the screen and the plastic border from any damage.
  2. Lenovo IdeaPad U410 Screen Replacement: paso 2, imagen 1 de 2 Lenovo IdeaPad U410 Screen Replacement: paso 2, imagen 2 de 2
    • Remove the six 3 mm Phillips #1 screws holding the screen to the laptop.
    • Ignore the "Do not touch" label on the bottom portion of the screen. It will not damage the laptop.
  3. Lenovo IdeaPad U410 Screen Replacement: paso 3, imagen 1 de 3 Lenovo IdeaPad U410 Screen Replacement: paso 3, imagen 2 de 3 Lenovo IdeaPad U410 Screen Replacement: paso 3, imagen 3 de 3
    • Lower LCD screen onto the keyboard.
    • Find the gold connector on the bottom of the LCD panel.
    • Gently grab the connector on both sides and pull the connector straight out.
    • Connector cable is very fragile. Use the least amount of force possible.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 1,442
