Saltar al contenido principal
Lenovo IdeaPad U410 Battery Replacement
Qué necesitas
  1. Lenovo IdeaPad U410 Battery Replacement, Bottom Cover: paso 1, imagen 1 de 2 Lenovo IdeaPad U410 Battery Replacement, Bottom Cover: paso 1, imagen 2 de 2
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Lenovo IdeaPad U410 Battery Replacement: paso 2, imagen 1 de 3 Lenovo IdeaPad U410 Battery Replacement: paso 2, imagen 2 de 3 Lenovo IdeaPad U410 Battery Replacement: paso 2, imagen 3 de 3
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
  3. Lenovo IdeaPad U410 Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Make sure your computer is turned off.
    • Lift the back panel away from you.
    • Locate the battery in the bottom right corner.
  4. Lenovo IdeaPad U410 Battery Replacement: paso 4, imagen 1 de 1
    • Remove the three 3mm screws located on the perimeter of the battery using the Phillips #1 screwdriver.
  5. Lenovo IdeaPad U410 Battery Replacement: paso 5, imagen 1 de 3 Lenovo IdeaPad U410 Battery Replacement: paso 5, imagen 2 de 3 Lenovo IdeaPad U410 Battery Replacement: paso 5, imagen 3 de 3
    • Locate the small rectangle shaped connector to the left of your battery.
    • Use your fingers to gently detach the white connector.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 848
