Saltar al contenido principal
Lenovo IdeaPad U310 Ram Replacement
Qué necesitas
  1. Lenovo IdeaPad U310 Ram  Replacement, RAM: paso 1, imagen 1 de 1
    • Make sure device is turned off and disconnected from any power source before proceeding.
    • Flip the device over so the bottom panel is facing up.
    • Remove the rubber feet by pinching and pulling in an upward motion.
    • The rubber feet are missing from this photo, but will be located within the red markups.
  2. Lenovo IdeaPad U310 Ram  Replacement: paso 2, imagen 1 de 1
    • Remove the 4 screws securing the bottom panel to the device.
    • The screws are missing from this device and are not pictured. They will be located under the rubber feet within the red markups.
  3. Lenovo IdeaPad U310 Ram  Replacement: paso 3, imagen 1 de 2 Lenovo IdeaPad U310 Ram  Replacement: paso 3, imagen 2 de 2
    • Place the plastic opening tool between the bottom panel and device.
    • Pry around the device's outer edge until the bottom panel is no longer attached.
    • Lift the bottom panel up and away from device.
  4. Lenovo IdeaPad U310 Ram  Replacement: paso 4, imagen 1 de 1
    • Pry the RAM's two holding clips in an outward motion.
  5. Lenovo IdeaPad U310 Ram  Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad U310 Ram  Replacement: paso 5, imagen 2 de 2
    • Continue to pry open the clips, and slip the RAM from its housing.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 20
Todo El Tiempo: 2,526
