Introducción
Replacing the keyboard on your Lenovo IdeaPad U310 could seem tricky at first. Be sure not to apply too much pressure to the keyboard for this might damage the plastic casing, and use the proper opening tools.
Qué necesitas
Flip the device over so the bottom panel is facing up.
Remove the rubber feet by pinching and pulling in an upward motion.
Remove the two 4.6 mm screws using PH1.
One is located next to the fan, the other at the corner of the battery.
2 personas más completaron esta guía.
Un comentario
Honestly, the best instructions for any task i ever made ⭐⭐⭐⭐⭐. Thank you
