Introducción
This guide outlines how to remove and replace RAM in a Lenovo IdeaPad S400 Touch. Replacing the RAM in your Lenovo IdeaPad could increase the performance of the computer, and can be done by following these four steps.
Qué necesitas
Turn your computer over so the back is face up.
Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
The battery cover will then pop up allowing you access to the battery.
Remove the five 6mm Phillips #0 screws from the back panel.
Pull back the rubber tabs from the corners of the laptop backing to expose the screws.
Remove the four 4mm Phillips #0 screws that are underneath the rubber tabs.
Remove the three 6mm Phillips #0 screws from under the battery.
Una persona más ha completado esta guía.
