Saltar al contenido principal
Lenovo IdeaPad S400 Touch Fan Replacement
Qué necesitas
  1. Lenovo IdeaPad S400 Touch Fan Replacement, Battery: paso 1, imagen 1 de 3 Lenovo IdeaPad S400 Touch Fan Replacement, Battery: paso 1, imagen 2 de 3 Lenovo IdeaPad S400 Touch Fan Replacement, Battery: paso 1, imagen 3 de 3
    • Turn your computer over so the back is face up.
    • Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
    • The battery cover will then pop up allowing you access to the battery.
  2. Lenovo IdeaPad S400 Touch Fan Replacement, Fan: paso 2, imagen 1 de 3 Lenovo IdeaPad S400 Touch Fan Replacement, Fan: paso 2, imagen 2 de 3 Lenovo IdeaPad S400 Touch Fan Replacement, Fan: paso 2, imagen 3 de 3
    • Remove the five 6mm Phillips #0 screws from the back panel.
    • Pull back the rubber tabs from the corners of the laptop backing to expose the screws.
    • The two tabs next to the battery flip toward the battery. The two remaining tabs flip down, away from the battery.
    • Remove the four 4mm Phillips #0 screws that are underneath the rubber tabs.
    • Remove the three 6mm Phillips #0 screws from under the battery.
  3. Lenovo IdeaPad S400 Touch Fan Replacement: paso 3, imagen 1 de 1
    • Slide the back panel away to remove it.
    • Don't be afraid to apply force when removing the back panel.
  4. Lenovo IdeaPad S400 Touch Fan Replacement: paso 4, imagen 1 de 1
    • Remove the two 5mm Phillips #0 screws holding the fan down.
  5. Lenovo IdeaPad S400 Touch Fan Replacement: paso 5, imagen 1 de 2 Lenovo IdeaPad S400 Touch Fan Replacement: paso 5, imagen 2 de 2
    • Unplug the fan's power supply cord.
  6. Lenovo IdeaPad S400 Touch Fan Replacement: paso 6, imagen 1 de 1
    • Pull the fan out.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 447
