Saltar al contenido principal
Lenovo IdeaPad S400 Touch Battery Replacement
  1. Lenovo IdeaPad S400 Touch Battery Replacement, Battery: paso 1, imagen 1 de 3 Lenovo IdeaPad S400 Touch Battery Replacement, Battery: paso 1, imagen 2 de 3 Lenovo IdeaPad S400 Touch Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Turn your computer over so the back is face up.
    • Use your forefinger to unlock the two tabs located on the back. Slide the tabs until you see the red showing.
    • The battery cover will then pop up allowing you access to the battery.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 395
