Saltar al contenido principal
Lenovo IdeaPad S340-15IWL Battery Replacement
Qué necesitas
  1. Lenovo IdeaPad S340-15IWL Battery Replacement, Back Panel: paso 1, imagen 1 de 2 Lenovo IdeaPad S340-15IWL Battery Replacement, Back Panel: paso 1, imagen 2 de 2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Battery Replacement: paso 2, imagen 1 de 1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Battery Replacement, Battery: paso 3, imagen 1 de 2 Lenovo IdeaPad S340-15IWL Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Disconnect the battery cable by gently pulling it straight out of the connector.
    • Be sure to pull parallel to the device to avoid bending the motherboard connector.
    • The battery connector does not lock and only requires light pressure to insert and remove.
    • Remove the battery from the laptop.
Conclusión
2 personas más completaron esta guía.
Un comentario
Worked wonderfully. Thanks for the great instructions.
Deb Dhar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 27
Ultimos 30 días: 131
Todo El Tiempo: 5,633
